well, i been using ath-sj3 to DJ and i want to get a better one because the ear muff skin* of my ath-sj3 has worn off, every time i wore it i will have black pieces all over my ear! any suggestion? budget about 50-80USD
geposted Mon 27 Feb 12 @ 9:54 pm
http://de.virtualdj.com/forums/141127/General_Discussion/What_headphones_do_YOU_use_.html
http://fr.virtualdj.com/forums/6065/Hardware_Technical_Support/what_kind_of_headphone_do_you_use_with_the_console.html
http://fr.virtualdj.com/forums/141127/General_Discussion/What_headphones_do_YOU_use_.html
its always good to search the forums first ;)
geposted Tue 28 Feb 12 @ 3:14 am
$50-80 isnt really going to get you anything great. Headphones are a vital part of DJing and you get what you pay for. So if you cheap out, you're just going to end up looking for another set in the not so distant future.
You can check out some of the headphones this company sells, and go from there:
http://www.pssl.com/Studio-DJ-Headphones?@sPriceLow&pg=100
Alot of people have these if you can up your budget a little and they seem to last and give good sound:
http://www.pssl.com/Sony-MDRV700DJ-DJRemix-Headphones
These Numarks have been getting alot of good reviews lately as well:
http://www.pssl.com/Numark-REDWAVE-Professional-Dj-Headphone
geposted Tue 28 Feb 12 @ 2:30 pm
Read this thread.
https://virtualdj.com/forums/145741/General_Discussion/A_good_head_to_head_comparison_of_3_top_notch_headphones_by_DJ_CITY.html
It might help point you in the right direction.
geposted Tue 28 Feb 12 @ 6:24 pm
So you ask, so shall you receive!
DJ RuDe
Keep Spinnin'!!
geposted Tue 28 Feb 12 @ 10:53 pm
Check out the Reloop RHP-10 Head Phones. They come in different colors and they sound good. The build quality is good because they are more fexible and stronger than many other brands. They are made of a strong composite material. They are not expensive plus, they give you features of $ 100 plus headphones.
geposted Tue 28 Feb 12 @ 11:59 pm
@rude, those look very similar to the numark PHX.
geposted Wed 29 Feb 12 @ 2:28 am
@Blulite - But not at all the same. The American Audio HP-550 also look like the Pioneer HDJ-1000 but are not the same.
DJ RuDe
DJ RuDe
geposted Wed 29 Feb 12 @ 2:35 am
Does the pioneer hdj 500 works good? I dont want the ear phone muff to get worn out
geposted Wed 29 Feb 12 @ 5:07 am
don't use headphones.....
I use Sennheiser ew 300 in-ear...
geposted Wed 29 Feb 12 @ 8:19 am
@rude, oh without a doubt theyre totally different in specification but looks, similar lol.
i dont tend to use my headphones a great deal anyway as i prefer to mix without or with monitors. i do use them to mark up cue points or check a track right quick but thats about it.
geposted Wed 29 Feb 12 @ 2:46 pm
I use the Numark PHX or Redwaves. I purchased the Redwaves for $50.00 & the PHX for $25.00. They are decent build quality, good bang for the buck.
geposted Sun 04 Mar 12 @ 2:50 am
These the Headphones that I have ,
Sony V700
Sound : 10
Comfort : 9
Insulation : 9
Esthetic : 8
Weight : 300 grams
Price : 99 €
Cons : Easy Break
Pioneer Hdj1000
Sound : 9
Comfort : 8
Insulation : 9
Esthetic : 10
Weight : 270 grams
Price : 179 €
Cons : easy break - Price
Technics RP-DJ1200 black
Sound : 8
Comfort : 10
Insulation : 9
Esthetic : 8
Weight : 200 grams
Price : 99 €
Good : price , comfort and durable - GOOD BUY
Pioneer Hdj 2000
Sound : 9
Comfort : 10
Insulation : 8
Esthetic : 10
Weight : 290 grams
Price : 269 €
Cons : PRICE !
Sennheiser HD 25
Sound : 10
Comfort : 10
Insulation : 10
Esthetic : 9
Weight : 140 grams
Price : 150 €
CONS : Nothing - GOOD : best of all my headphones .
Sony V700
Sound : 10
Comfort : 9
Insulation : 9
Esthetic : 8
Weight : 300 grams
Price : 99 €
Cons : Easy Break
Pioneer Hdj1000
Sound : 9
Comfort : 8
Insulation : 9
Esthetic : 10
Weight : 270 grams
Price : 179 €
Sound : 8
Comfort : 10
Insulation : 9
Esthetic : 8
Weight : 200 grams
Price : 99 €
Pioneer Hdj 2000
Sound : 9
Comfort : 10
Insulation : 8
Esthetic : 10
Weight : 290 grams
Price : 269 €
Cons : PRICE !
Sennheiser HD 25
Sound : 10
Comfort : 10
Insulation : 10
Esthetic : 9
Weight : 140 grams
Price : 150 €
geposted Sun 04 Mar 12 @ 6:58 am
Ive been using the Sony v700 listed already in this thread for about 10 years. I might get something else someday, but you can't go wrong with these.
geposted Sun 04 Mar 12 @ 10:37 am
hey thanks everybody for your reviews and comments! :)
geposted Tue 06 Mar 12 @ 5:38 am
I personally use studio type headphones... Sony MDR-V150.... Can only buy them at Sears for around $20 with a warranty it is $25 the warranty in itself made me get them... Not one week went by and the bracket broke... Brought them back and they game a brand new set right in a box... no questions asked.....
geposted Tue 06 Mar 12 @ 7:11 pm
djppdkk,
regarding the in-ear headphones you use, do they eat up 9v batteries like crazy? I have a set of Shure in-ear monitors that I use when I play in my band, but the receiver I wear goes through 9V batteries pretty quickly. I would consider using them, now that you mention it, but I don't want to be replacing the batteries all the time.
blainele,
"Can't go wrong w/ Sony v700..." Completely agree w/ you there. I've had mine since 2000 and they still sound great.
blainele,
geposted Tue 06 Mar 12 @ 8:51 pm
Denon DN-HP1000 & Pioneer HDJ1000... both work perfect for me.
geposted Wed 07 Mar 12 @ 12:40 am
was using the pioneer hdj1000 for a few years but recently switched to the (Don't Be A Hater#) Skullcandy Mixmaster Mikes
awesome
awesome
geposted Wed 07 Mar 12 @ 1:37 am
I use these.
geposted Wed 07 Mar 12 @ 6:42 am
