Hi, I need some help because i have a problem with my Living Electro LE installation.
Last year i bought a Gemini CTRL ONE on ebay with a compatible CD of Living Electro LE,
the problem is that normally the serial number is writen on the back of the product (Gemini CTRL ONE)
but it's not writen on mine ! What should i do ? Can you help me please ?
Thank you very much for helping
PS: Sorry for my english spelling i'm from mauritius.
I hope than you'll understand
geposted Tue 28 Feb 12 @ 3:20 am
hi, the serial number is usually written on either;
a: the cd
b: the cd packet
c: the instruction manual
if it is in none of these locations i suggest you return it o the store from where it was purchased, or contact gemini for a new serial number.
hope this helps. john
a: the cd
b: the cd packet
geposted Tue 28 Feb 12 @ 4:27 am
Please see here:
virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.htm
You will have to contact Gemini directly and give them the. controller serial to see if they can help
Thread locked
Keith
Thread locked
Keith
geposted Tue 28 Feb 12 @ 4:53 am
