I am looking for an option to SCAN the MP2 while loading it into a deck.
Sometimes I ended up replacing the mp3 and when I load that new mp3 into a deck,it clips. I had to re-scan it then re-load.
The option will be helpful (for me at least) when i load the mp3 into the playlist for auto mix (if the mp3 is re-placed, the sound will be LOUDER) and that mp3 needs to be re-scan (thats how I can tell).
I know this is not for 98% for all DJ out there, but for me it's alot.
Is there an option to what I'm looking for ?
Maybe a script or something to just scan it and load (just like it's the first time loading the mp3).
thnx.
thnx.
geposted Tue 28 Feb 12 @ 2:54 pm
PreScan before using it is the best way to deal with it, additionally you could preListen the track before it loads...prep is key always...
Good Luck,
Joey..
Good Luck,
Joey..
geposted Tue 28 Feb 12 @ 6:11 pm
geposted Tue 28 Feb 12 @ 7:57 pm
