Hello,
I bought a new maya44, and i want to connect my players to virtual dj.
My setup:
2 x Reloop RMP-1
1 x Behringer VMX 300
1 x Maya44 usb
My laptop is windows XP. So i did everything and VDJ do not records my music, shows the waveform or anything. So I think, I did something wrong. I know this setup is not the best, and a bit old, but can anyone help me with this?
Some pictures:
My Setup:
http://postimage.org/image/y6lrk587x/
The timecode config:
http://postimage.org/image/ys04f8f75/
My Maya44:
http://postimage.org/image/ekuhs5zon/
Thanks for your help!
Best Regards!
My setup:
2 x Reloop RMP-1
1 x Maya44 usb
Some pictures:
My Setup:
My Maya44:
Best Regards!
geposted Thu 01 Mar 12 @ 11:36 am
Please see:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
Your CPU also appears to be maxed out in both those screen shots, so you probably have performance issues with your computer and/or it isn't powerful enough. Please see: https://virtualdj.com/wiki/Performance%20Issues.html
geposted Thu 01 Mar 12 @ 12:31 pm
Well I don't really want to record it, I want to use it in live to see the details of the song and etc. Use the cd players not the mixer only. Also the first link is not works for me. BTW Thank you.
Well I will ask this in a different way, will the reloop RMP-1 able to scratch, cue, play, etc. in vdj?
Thank you.
Thank you.
geposted Thu 01 Mar 12 @ 12:39 pm
Please try the link again.
The RMP-1 will work if you use timecode CD with the full VirtualDJ Pro: https://virtualdj.com/wiki/Timecode%20Requirements.html
Please see the following page for info on how to configure the Maya44: https://virtualdj.com/wiki/Maya44%20USB.html
geposted Thu 01 Mar 12 @ 2:54 pm
Thanks alot!
geposted Fri 02 Mar 12 @ 12:01 am
