Hi guys can anyone help? i have vdj pro, ive introduced alot to vdj free, now it says you can add mic and i remember there was an add on, but i cant find it, so can someone direct me to it? and also is there some basic intructions to make it work?, most i have using vdj use it on a computer with no hardware, thanks
geposted Thu 01 Mar 12 @ 4:56 pm
plz note this would really help, i run an online radio station with 30 odd people broadcasting on it
geposted Thu 01 Mar 12 @ 6:40 pm
config > sound setup > advanced config > hit + > select microphone > select input source > apply > ok > apply > ok
thats your mic setup and ready to use.
hope this helps, john.
geposted Fri 02 Mar 12 @ 12:13 am
