Hey guys and gals,
I was not sure where to post this so if it is in the wrong place I apologize....
I was wondering if anyone could give me some advice here... I tried posting something on the QSC forums but no one seems to care about helping someone with info...
What I am planning on getting is the follow Denon MC6000 with Glider Case, DBX Driverack (Not sure model yet), wither one of the following 2 X QSC K10's with 2 X Ksub or 2 X KW152 with 2 X K181.
I currently use the Driverack PA for my Denon DN-HD2500 Rig and it works great so I want to keep it with that as a wedding system.... I am thinking of getting either a PA+ or PX for the new QSC's.. I know that I don't need it but it has a nice notch filter system for feedback and Parmetric eq and Graphic eq plus I use the RTA at every single event....
As far as the QSC's go... Who here (I know alot have started using them) Has used them in that kind of setup with a DBX before or currently... What is the better setup to work with long term... Eventually I am going to have both and replace my Mackie's with the K10's...
If my thinking is correct with using the Driverack I can run 2 configurations.. 1 would be run just out of the Hi Left Right Like normal or I could configured it to run as a true system with Limiters in place (My 1st choice) where you have L/R in to L/R Out Hi's and L/R Out Subs...
Please help out a newbie with Higher End Equipment.....
geposted Fri 02 Mar 12 @ 8:48 pm
You can run your Driverack in two way stereo mode either L/R outs to L/R Highs and the L/R lows outs to L/R Subs.... or if you want to do it in 3-way stereo mode by just adding another pair of L/R MID's speaker cabinet in between high & lows.
geposted Sat 03 Mar 12 @ 6:29 am
