Hi everyone,
I'm trying to run two lpd8's with hercules rmx on Mac... I'd like to use both lpd8"s each for one deck but vdj allways sees only one of them.
I made a new configuration in AudioMidi Setup app (added two new midi devices, one for channel 1 and the other for channel 2 - even Akai Editor showed changes)..
Then I used the old sysexid="F07E??06024775001900000066000000000000000000000000000000000000" only instead of ?? I put 01 and 02 with the correspondig def file...
I even try to add devicename="Lpd8 1" and devicename="Lpd8 2" after sysexid (in order to override it) but nothing seems to help..
Does anyone has any ideas why it's not working?
Thanks in advance...
geposted Sat 03 Mar 12 @ 1:20 pm
Nevermind... I've figured it out... Just forgot all about the hexidecimal...
So instead of 01 and 02 I had to put 00 and 01 to sysexid ... and name all channels same way...
geposted Fri 09 Mar 12 @ 5:04 pm
