Hey everyone-
Longtime lurker, but always come here for help.
I'm looking to see if anyone can tell me how to combine XML files? I've switched hard drives and would like to retain my cue points and playlists.
Thanks in advance for your help.
Nick
Nick
geposted Sat 03 Mar 12 @ 7:14 pm
you just need your music files in the exact same filepath, then put the database file from the old computer in the vdj folder of the new.. but really you can just copy the entire folder over, so you keep your plugins and skins....
If changing tge file path is unavoidable you can open the xml in a text editor and use find and replace to modify the start of the filepath up to the common part
geposted Sun 04 Mar 12 @ 3:44 pm
Thanks synthet1c-
Here is my main issue, i had two separate 1TB HD; they weren't the exact match of data. I went out and bought a 4TB (2TB +2TB) HD with a raid 0. So I basically took the two separate HDs and copied their info to the 4TB HD.
I think the only way to do this is open up both the xml files from the individual 1TB Drives and copy and paste one into the other.
Nick
Nick
geposted Mon 05 Mar 12 @ 1:33 pm
