I have read as much as I can absorb regarding DMX lighting. Having a computer programming background, the vast majority of DMX seems reasonably straight forward.
I like the perceived flexibility of a software based DMX solution and have been able to trial one product (Venue Magic) and got it integrated with Virtual DJ.
Does anyone have hands on experience with software based DMX controllers and feel confident to give a recommendation regarding reliable well engineered DMX controller software?
Thank you in advance.
geposted Sun 04 Mar 12 @ 1:12 am
If you want integration with VDJ then your choices are VenueMagic or FreeStyler at present. I've been asked to add DasLight which is popular too.
geposted Sun 04 Mar 12 @ 5:41 am
what about MyDMX from ADJ ??
geposted Sun 04 Mar 12 @ 6:29 am
Personally I'm not a fan.
geposted Sun 04 Mar 12 @ 7:16 am
As far as I know that program (MyDMX) doesn't have sound to light function. Freestyler is pretty good (AND IT'S FREE) and is what I use with SBDJ's freestyler plugin.
geposted Sun 04 Mar 12 @ 3:43 pm
I have Virtual DJ LE that comes with midi hardware controller, how can I get this plugin?
Will I be able to download it or can someone send a link.
I want to control lights with the beat in freestyler using virtual dj le.
Thanks in advance.
Thanks in advance.
geposted Wed 07 Mar 12 @ 5:45 pm
Blizzard's Eclipse has beat syncing. It is very good, and you can try it for free from Blizzards Web Site.
geposted Wed 07 Mar 12 @ 6:00 pm
It requires Virtual DJ Pro.
geposted Wed 07 Mar 12 @ 7:01 pm
is there anyway to intergrate dmxis
geposted Thu 08 Mar 12 @ 8:44 pm
If we're tossing out requests, what about Lumidesk?
geposted Mon 29 Oct 12 @ 9:36 am
Current options are VenueMagic, FreeStyler and TheLightingController (Sweet light/ShowXpress). Others can be added if they have SDK support.
I've been unable to get the Daslight SDK to work and Daslight support replied to my first message and then stopped.
geposted Mon 29 Oct 12 @ 12:52 pm
Not really interested in Daslight. How do I find out if lumidesk is affable?
geposted Mon 29 Oct 12 @ 12:56 pm
What about DMXIS and Show Buddy by DB Audioware?
geposted Thu 27 Feb 14 @ 5:52 pm
I personally swear by freestyler. Not only did SBDJ make an incredible plug in for it but the software is incredible for a free software. It does have a learning curve but once you understand it, it literally opens up the world as far your lighting goes and it allows me to do some insane light shows while I am playing.
geposted Fri 28 Feb 14 @ 7:26 am
I'm using Freestyler with the SBDJs plugin. Once you understand a few basics, it's pretty simple. There's still a few things I haven't got to work right, but it's doing the job as is.
Here's a clip of me messing around with it. I've since done way more stuff with it.
http://www.youtube.com/watch?v=XYNlPKNjVlY
geposted Fri 28 Feb 14 @ 7:34 am
I love Freestyler, got a $60 DMX box from ebay, works great.
geposted Fri 28 Feb 14 @ 1:11 pm
Which DMX boxes are you guys using?
geposted Sat 01 Mar 14 @ 12:33 pm
Does the free DMX-Software DMX-Controll 2l goes with VDJ Pro Full ?
http://www.dmxcontrol.de/
mfg,dirk
mfg,dirk
geposted Sat 01 Mar 14 @ 3:11 pm
Dirk, your question is already answered in the second post:
VDJ itseld is not capable to control DMX-lighting but VenueMagic and Freestyler can both respond to commands, send by the plugins SBDJ wrote. For compatibility you could check the forum of DMXControl.de.
@AMAHM: The Enttec DMX Pro. I've been using the Velleman K8062. It works, but the response of this module is slow and it gets worse when using more DMX-channels.
geposted Mon 03 Mar 14 @ 3:09 am
I just bought an entec usb controller and it runs everything I have really well........ I dont notice any lag of course I use amplifiers for my longer runs and dmx terminators.... For under $50.00 I have a system that controls all my lighting .... well 300 of you count the 26 inch multitouch screen I use for cue points and overrides.....
geposted Mon 03 Mar 14 @ 6:58 am
