Forum: Old versions
Topic: Recording with smfx 200
Hi
I am trying to record a set with my citronic smfx 200 it has 2 usb inputs which i use for vdj i have tried to record a set with vdj and when i record it it is recording the other deck that i am cueing up also ? how could i set it up to record from each channel on the mixer ? It works perfectly on the master out on the amplifier when i am mixing ?
geposted Tue 06 Mar 12 @ 7:25 am
SFMX 200 is an external mixer. VirtualDJ LE does not support this setup except in the 20 day trial of the full Pro. You will need to upgrade to the full VirtualDJ Professional to use separate deck outputs to an external mixer.
If you have already purchased VirtualDJ Professional, please register your serial number on the page https://virtualdj.com/users/edit.html and download the latest version from the Download Center: https://virtualdj.com/download/updates.html
Otherwise, please support the software and its future development by purchasing it: https://virtualdj.com/buy/ - Your VirtualDJ LE entitles you to a discount off the cost of upgrading.
To record correctly when using an external mixer, please see our FAQ pages:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
