I just bought a Numark Mixtrack Pro and downloaded the LE version, but it won't let me sign in to my premium membership. Because I use NetSearch, & since there's nothing there for me to sign in with I cannot access the NetSearch.. It randomlly worked one time for me, but then when I closed the program.. NetSearch was gone again & nothing would let me sign in.. Can somebody please help??
geposted Fri 09 Mar 12 @ 10:26 pm
geposted Sat 10 Mar 12 @ 12:36 am
Sorry, can't help with your problem but bumping your thread after only 2 hours is a quick way to get flamed around here....
geposted Sat 10 Mar 12 @ 12:55 am
Have you checked in config to see if Virtual DJ shows you connected? Go into Config, then the internet tab. Make sure the it shows you connected, and not limited membership. Also make sure the Netsearch checkbox is checked.
geposted Sat 10 Mar 12 @ 9:42 am
