I've been working on a mix of Sorry for the Party Rocking and Party Rock Anthem. For some reason, Party Rock Anthem is playing way louder then Sorry for the Party Rocking. Even when the volume down its still playing loud.What do I do
geposted Sat 10 Mar 12 @ 9:16 am
What version are you using and how do you have your setup connected?
geposted Sat 10 Mar 12 @ 9:52 am
Im using the home 7.0.5 and what do you meen
geposted Sat 10 Mar 12 @ 11:13 am
mate download free software mp3gain.
set the db to 94 and then just analyze tracks then add gain.
now all mp3 same level
geposted Sat 10 Mar 12 @ 12:25 pm
You should be able to rescan you library and detect the volume without using a separate program. VDJ does a good job of setting the initial gain. Right click on the files in your library and re-analyze the BPM. You can do them in bulk by selecting a bunch of them, right click, and scan for BPM. This will also set the audio gain. Loading a track and adjusting the gain knob will also do this, but manually.
I asked about your setup, meaning what is the equipment you are using. PC - Mixer - Speakers, etc. you could be introducing gain somewhere else depending on how your sound is set up.
geposted Sat 10 Mar 12 @ 4:45 pm
make sure auto+Remember is on...In the settings
geposted Sat 10 Mar 12 @ 7:00 pm
Ok I've try that. Party Rock is stil a bit to loud, but its can work. Thank
geposted Sun 11 Mar 12 @ 11:36 am
Are they both the same type of file, with the same bit rate? Are the mixer levels in the software the same? Is it still louder if you play in the other deck?
geposted Sun 11 Mar 12 @ 12:42 pm
You simply could not have chosen two worse songs.
geposted Wed 25 Jul 12 @ 10:34 pm
