Hi folks wondered if you can help me:
Once a month I play in a venue that has their speakers at opposite ends of the room. I play a lot of old funk and jazz where there is a wide stereo separation, so for some tunes if you are standing at one end of the room you cant hear half the instruments. Is it possible to set VDJ to output a mono sum of the left and right channels on both the left and right output channels. (their club mixer does not have this feature).
I am using VDJ 7 pro with a hercules rmx as the controller and soundcard.
Also from time to time I get a small lag of the music (say for 1/2 a second the tune slows down) If I am beat mixing they do not go out of time just slow down by the same amount then return to normal. I am assuming this is a latency issue but any tips would be gratefully received.
John
John
geposted Sat 10 Mar 12 @ 2:42 pm
I quess that the mono sound configuration can be done with the advanced sound panel...with the tick of a box and routing your sound channels the way you want...
and i think it would be easier to get more help in the greek forum of vdj....I quesss you speak greek since I see your mother country is Cyprus...
geposted Sun 11 Mar 12 @ 8:32 am
will see if I can find an option in advanced config.
Even though i live in cyprus and am half Cypriot I am afraid my Greek is pretty non existant (shameful I know)!
John
John
geposted Mon 12 Mar 12 @ 4:45 am
