Hi all,
I search but I wasn't able to find where I can get information on the newer update v7.0.5b
I currently i'm running 7.0.2 and just want to know what was added or improved.
Thanks
caddog705
Thanks
caddog705
geposted Sat 10 Mar 12 @ 10:41 pm
https://virtualdj.com/wiki/VirtualDJ_History.html
VirtualDJ 7.0.3 (7 March 2011)
fixed microphone sound with non-ASIO soundcards
fixed compatibility with 48Khz-only ASIO drivers
new VDJScript verb: "repeat"
fixed action "motor_switch" (fixes HS5500 in dual-layer mode)
new registry SendMidiClockTo; midiclock removed from general midi mappers
new MIDI definition syntax: <inputsysex>
fixed IVdjPluginMapper plugins
fixed vinyl mode in config option to affect decks>2
don't register as ReWire master until vdj is actually using it
MAC: fixed crash when automixing karaoke
MAC: fixed filter folders using "days since xxx"
MAC: fixed deleting playlists
MAC: fixed get bitrate informations
MAC: fixed sort by file date
VirtualDJ 7.0.4 (05 May 2011)
changed default JogSensitivityScratch to 200% (on fresh installs)
new registry JogSensitivityScratchMotor (default 100%) for separate setting for motorized platter
fixed a potential bug in ID3 tag writter
fixed double \ in paths with new installer (caused sonique plugins not to open)
fixed crash in coverflow when height was exactly 1 pixel
release hold on touch_jogwheel when switching vinyl_mode
fixed pitch_range brings the pitch of all decks in range
fixed sampler switches automatically to "pitch-lock" when a loop is recorded
CD and network volumes don't show error popup when browsed (to still get login popup for network drives, hold CTRL while clicking on the drive)
fixed rare crash when deleting a cue point
fixed a possible crash when using several HID controllers and disconnecting one
MAC: fixed changing latency settings
new registry AutoPitchRange to change the range when needed by a bpm-match
new vdjscript: "get decks" or "get decks 4 ? ..."
new vdjscript: "get effect_button_name" and "get effect_slider_name"
VirtualDJ 7.0.5 (07 August 2011)
fixes video stream errors
added new formats to the video decoder engine
support firewire controllers
18 new controllers added
fixed opposite chan sync in multi-deck
fixed "leftcross off" and "rightcross off" when cross is already assigned to the other side
fixed changing vinyl mode/cd mode while touchwheel_touch is kept pressed
new action "get beatdiff"
new action "effect_select_multi"
new midi definition element: <led note="" min="" max="">
fixed midi definition element <fulljog pitch="">
VirtualDJ 7.0.5b (17 August 2011) (PC only)
fixes crash when playing old Promo Only videos with bad encoded dates
geposted Sat 10 Mar 12 @ 11:03 pm
Thanks blackjack... :)
I knew this information was somewhere...
:o)
I will update my VDJ tonight...
geposted Mon 12 Mar 12 @ 7:41 pm
Update all done with no problems...
Thanks again BlackJack... :0)
geposted Tue 13 Mar 12 @ 10:55 am
