Good morning,
I recently purchased a Pioneer Ergo to replace my old Hercules RMX and also upgraded VDJ LE to VDJ Pro.
Now, my question is as follows : On the RMX, you had a "pitch reset" button which I seem not to find o the Ergo!
I know that there is a functionnality called "pitch reset on load" in the VDJ parameters, but even once enabled, it doesn't seem to work...
Any help?
Thanks,
jeff
Any help?
Thanks,
jeff
geposted Mon 12 Mar 12 @ 5:50 am
Hi Jeff, do u have solved the problem about the "pitch reset"? I am looking too but I use now only CTRL + * . do you have other news?
Thanks
Massimo
Thanks
Massimo
geposted Wed 21 Mar 12 @ 7:21 am
Sorry, the Pioneer DDJ-ERGO doesn't have this feature mapped by default.
However, you can change the mapping of any button of your own choice to this function if you wish (E.g: A button that you don't use)
Simply map the button to the following action: pitch_reset
For further information on how to change the mapping of buttons, please see:
https://virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
geposted Wed 21 Mar 12 @ 8:31 am
Thanks a lot for your support and your advice
Massimo
Massimo
geposted Wed 21 Mar 12 @ 8:48 am
