I have upgraded my pro7 with a high resolution skin it works great however I get a warning of the program being too high in resolution for my screen when loading do I need to correct this as when I click continue it loads ok and runs great. Is there a setting on the Macbook to raise the resolution of my screen? if yes where is it?
Thank you
Steve St John
Toffs Mobile Disco
Thank you
Steve St John
Toffs Mobile Disco
geposted Mon 12 Mar 12 @ 7:44 am
Steve,
you can decrease your resolution, not increase it. Your solution would be to search for a skin with the same resolution as your MBP-screen. If it's not available, you can resize your current skin to the proper resolution with the Skin Resizer Tool: https://virtualdj.com/addons/7187/Skin_Resizer_Tool.html
Make sure you DL the Mac-version.
geposted Mon 12 Mar 12 @ 9:38 am
