had look all over the net on how to get Asio4all to work on VDJpro it kept saying not enough channels then I realised well its too many chanels Ah I have an idea...
do this....
before you run vdj make sure your devices are recognised & asio4all is installed
run vdj
goto settings audio:
select option 1 audio device looks like a pc with one speaker
then select asio4all and config it
then config asio4allits self by clicking the spanner click the usb devices of your units mine was usb-audio1 & 2 and click off on the pc device if you dont need it
the click the spanner adjust the latency close
got to setup and select outboard mixer
asio4all should now work and open its config pannel
I still have problems with my ndx900 its hammering my pc proccessing but the asio4all in running just!!!!
do this....
run vdj
geposted Mon 12 Mar 12 @ 10:36 am
Please don't spam the forums with that post.
geposted Mon 12 Mar 12 @ 11:47 am
