Hi all
really struggling with this so any help is appreciated. How would i configure my Saffire pro 14 with virtual dj pro?
At the moment I can't hear the other channel through my headphones when plugged into the pro 14 when i want to cue it to bring into the mix? Hoping someone else has a saffire product and had similar initial problems with configuring it.
for info
i run 2 KRK monitors from my saffire using DAW 1 and DAW 2 routed and my overall Routing Preset is set to zero latency monitoring.
the PFL button in vdj doesn't seem to change the headphone input either?
I basically want to replicate the same config as if i was using a real mixer with 2 decks?
thanks!
for info
thanks!
geposted Mon 12 Mar 12 @ 11:39 am
