Does anyone know of a way to have the master volume automatically set itself to 50% when Virtual Dj is first started?
Thanks for your help
J
J
geposted Thu 15 Mar 12 @ 4:28 pm
If you are using a midi controller you just need to map ONINIT with typing "master 50%" in the action box, this will be performed when vdj recognises the device for the first time... you can also do it with a skin but that is a little more complcated.
This is how to find ONINIT in the mapper
geposted Thu 15 Mar 12 @ 5:54 pm
Thanks Synthet1c I mapped it into my midi controller and it worked perfectly.
geposted Fri 16 Mar 12 @ 10:32 am
