Just received my VMS2 plugged everything in ..... loaded up a track but ive got no crossfader???????? any ideas?????
geposted Fri 16 Mar 12 @ 6:04 am
In fact the VMS2 isnt controlling anything on the laptop!.....
geposted Fri 16 Mar 12 @ 6:12 am
First you need install the firmware/driver of your controller. Try to check the VDJ controller list just to see if your controller is locally supported by VDJ if not you may also download the mappers in the Virtual DJ download area but that is only for VDJ PRO license user, you can upgrade yours and registered to PRO user version to be able to have all the benefits of full functionality of the softwares. Being an NLU is limited and i'm worried that you can't do anything on that.
After doing all the steps above, you may have to add and setup your controller in the audio midi setup in the system profiler of MAC OSX.
Try to read this blogs how add and setup your controller in MAC OSX. Hope this may help you.
https://virtualdj.com/homepage/cesarcastillo/blogs/4702/What_To_Do_If_USB_DJ_Midi_Controller_Is_Not_Recognized_By_Mac_OSX.html
geposted Tue 20 Mar 12 @ 2:03 am
