Forum: Old versions
Topic: How to sync Traktor pro/numark mixtrak pro/roland 303!?
Hi
I've been directed here by staff at the Numark forum as they wern't sure. Seems you guys are the place to ask!
After happily using traktor pro and my numark with a macbook pro and I'd like to sync my roland 303 using the midi clock on Traktor pro and have some audio out from the 303 to add to my mixing.
I'm a bit stuck as to what to do as the numark pro soundcard only has 2 pairs of audio outs.
I'm wondering if I can use another usb out (using a usb to midi cable) from my macbook and use that to provide the midi clock to my 303?
If not possible, do I need to disable the soundcard on the numark (how to do that!?) and use an external soundcard (I own an M Audio Quattro) as the audio/midi interface?
Thanks for the advice!
geposted Fri 16 Mar 12 @ 8:18 am
Unfortunately, they have directed you to the wrong place.
These are the forums of VirtualDJ software, not Traktor, which is a competing product.
For help with Traktor, please go to their support website/forums (Search Google.)
You can also try out our DJ software VirtualDJ by downloading VirtualDJ Home FREE from https://virtualdj.com/download/free.html
