Hi all,
I'm using two DN-S3700's with Virtual DJ and am loving how seamless everything is working so far :)
Just wondering if there is any way to get a folder to collapse while you are inside it? The back button on the Denon will open and close the folder, but only if you have the parent folder highlighted. I'm looking for a solution to collapse the folder I am currently in even if I'm half-way through scrolling through it.
Any thoughts?
Cheers,
Pete
Any thoughts?
Cheers,
Pete
geposted Fri 16 Mar 12 @ 9:16 pm
