Hi everyone,
i'm currently buying stuff to dj at a couple of partys. I have 2 msr400 speakers ( http://www.zzounds.com/item--YAMMSR400 )
I'm planning on buying a Yorkvill LS700P subwoofer to go with them ( http://www.alpha-music.com/productcart/pc/viewPrd.asp?idproduct=5499 )
But a friends of mine keeps telling that i should buy 4 speakers and no sub instead of 2 speakers and 1 sub. He tells me to buy a pair of these speakers : http://www.amazon.com/Behringer-EUROLIVE-B212D-1-35-inch-Compression/dp/B002C4N8TM
Should i listen to him? What would be the best 2 msr400 + 2 b212d or 2msr400 and 1 LS700p sub ?
Thx!
geposted Sat 17 Mar 12 @ 7:06 pm
Don't Listen to him!
geposted Sat 17 Mar 12 @ 7:32 pm
Your 2-mrs400's + Yorkville ls720p (15" sub)
geposted Sat 17 Mar 12 @ 10:24 pm
Dont buy 4 behringer speakers. Buy the 2 yamaha speakers and this subwoofer http://www.guitarcenter.com/Harbinger-HP118S-Powered-Subwoofer-105471353-i1478660.gc Dont buy that Yorkville double 10 inch sub because it wont give you a great bass responce. You can only hear great bass form a 18 inch woofer. Not a 10, 12, or 15. A 15 inch will sound Ok but, it wont give you that good low end of a 18 inch.
geposted Sat 17 Mar 12 @ 11:31 pm
So you don't really recommand the ls700p?
geposted Sun 18 Mar 12 @ 2:03 am
Caliente is my boy, and no disrespect to him at when I say that the 700P is a great powered sub. Yes, I agree that a 15 and even better 18 inch will give you a lower rumble, I've done huge rooms with one or two of the 700Ps with great results. I too own many 18" and 15" subs, both active and passive.
When I'm on a one man job and don't have the man power to load bigger subs and amps, the 700P is a great option.
geposted Sun 18 Mar 12 @ 1:54 pm
The Harbringer is a great sub too!
geposted Sun 18 Mar 12 @ 1:55 pm
Whats Good my Brother Kizzle. Its been a while. If i had a gig for 100 people, the 15 inch yorkville sub will work nice with two powered speakers. I can setup quicker because the sub is more portable.
geposted Sun 18 Mar 12 @ 9:29 pm
caliente is right
a double 10 inch calls itself a sub ?? really????????????????????
geposted Sun 18 Mar 12 @ 9:32 pm
Yes. Fact. Good for small parties that need some bottom end.
geposted Sun 18 Mar 12 @ 9:45 pm
I've used 2 Mackie SRM-450's with a CV Earthquake and wished I had more bottom end. Granted it was an outdoor gig. :-)
geposted Sun 18 Mar 12 @ 9:53 pm
kizzle if you say it's good for a small party , then i'm sure it is
i still think Caliente was right saying 15" and up is usually the starting size for a subwoofer......
blckjck .....outdoors you need way more power than normal, that system you mentioned is
a good set up for many indoor events......
i haven't heard a Bose , Denon ,or Cerwin-Vega sub that i didn't like
i was testing a Denon down firing 10 inch at a Circuit City? i think it was , blasting
some classical music for a test listening and the speaker levitated up off it's shelf
another occasion at a warehouse up in northern NJ , blasting Allman Bros. thru
a 2000 ? watt system with a 30" CV in a closed cabinet .... it was awesome, the huge glass windows
out front were vibrating from the sound pressure ......
gents if you guys are into great bass sound get some of the VST plugins for EQ .....
i have Classic Eq by kjaerhaus audio ..... great semi parametric , harder to find anymore it's abandonedware
thank you DJ in Norway for recommending that to me .....
another goodie is EQ 18 ......18 bands graphic ...but it only has 2 hi bands at 8khz and 12 khz ......which means it has 16
bands for the lowest lows thru the high mids .....so you can really have your way with it with the
lows. the 2 lowest bands at 20 and 31 work great so be careful depending upon the strength of your
speakers
speakers
geposted Mon 19 Mar 12 @ 12:00 am
Right now i am using two JBL Prx 615m speakers with the QSC KW 181 sub and it sounds really nice. The biggest prviate gig i DJ yed last year was for the marines. It was 300 plus in Attendance. The speakers sounded great for a large room but, i think i may need another KW.
geposted Mon 19 Mar 12 @ 12:17 am
that's a good system.....
interesting too the connection of speakers and the military ...
James B Lansing & Sons was a small but good company when it landed it's first
big contract with the Army .... i believe they are the guys that developed kevlar
into speakers, and originally for the military .....
geposted Mon 19 Mar 12 @ 12:31 am
