Hi,
I'm having issues with my deck #1 when ever i activate timecode for it. It never goes to silent. Anyone has had that issue before?
I'm using an audio 8 DJ with VDJ 7.
Thanks
Thanks
geposted Sat 17 Mar 12 @ 9:00 pm
99 times out of 100 it the grounding of the turntable... dissconnect then reconnect the ground, if that doesn't fix it remove the headshell and check the wires...
geposted Sat 17 Mar 12 @ 10:54 pm
I don't think CDX has those grounds. Also, if i use 4 deck and use the same turntables for deck 2 and deck 3, i dont have that issue. Seems to be associated with deck1 in the software.
I though it was maybe the inputs #1 from my audio 8 dj, but i keep the same input #1 on my soundcard, but said to VDJ to associate input 1,2 to Deck 3 and I dont have the issue no more :S
geposted Sun 18 Mar 12 @ 11:11 am
Anyone else has this issue with deck #1?
geposted Sun 18 Mar 12 @ 6:22 pm
This has more likely to do with either your settings in TC config for deck #1 or the first channel on your Audio 8 DJ.
If this issue remains, you should post pictures of your setup and especially screenshots from your TC config.
Differences between the software decks themselves are - sorry - complete rubbish.
geposted Tue 20 Mar 12 @ 5:12 am
