Adam,
Great skoin. Anyway to get this to rotate to Landscape to the other direction? When I use the built in stand on my iPad folder, it's upside down.
Thanks,
Thanks,
geposted Sun 18 Mar 12 @ 7:58 am
I have the same issue. Wish the skin creator had a flip option! Started looking into it and it is not as simple as rotating the graphic.
Without the search and Auto play list management, there is just not enough reason to spend any time on skin improvements. Lets hope VDJ 8 brings a better iRemote too!
geposted Sun 18 Mar 12 @ 6:48 pm
Even if the Skin Creator / Resizer had a rotate feature, it wouldn't really be useable because all textzones would be upside down.
geposted Mon 19 Mar 12 @ 7:43 am
Ah, good point! Well, chalk up screen rotation as is wish for iRemote!
Seriously thought, the Search needs to make it into iRemote first though.
geposted Mon 19 Mar 12 @ 1:36 pm
