Forum: Old versions
Topic: Mixvibes Vfx Control
Hello Team !
I have Mixvibes Vfx controller and would like to use it with VDJ 7.0.5 pro for small parties .
Vfx is same (copy) of American audio DP2 but i cannot map second player )i know there is no support for that controller
When i try to instal DP2 drivers it can not recognise vfx controller .
Is there a way to change VFX name to DP2 somewhere ? maybe than i could instal DP2 drivers ?
THX !
geposted Sun 18 Mar 12 @ 4:25 pm
Sorry, Mixvibes VFX is not natively supported - Please see: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
To use this controller, you would need to manually map it yourself: https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
While it may look like the DP2, it's firmware and internal programming will be different.
The American Audio DP2 is natively supported by VirtualDJ and built into the software. It's not available separately.
NOTE: We always strongly recommend purchasing a controller that is already natively supported by VirtualDJ.
