i need help to clarify something and know more about so please answer me in detailed to my question, thanks ! (:
1.Does the mixdeck (all series) is fully midi? mixer and the cdj. Then if i want it digital, can the mixer work?
2.If i were to buy only TWO pioneer cdj-350 and a 4 channel mixer, am i able to use up all the 4 channel on the digital turntable?(like is there a button for me to switch from deck 1,2,3,4?)
3.I have a sony SRS-D211 and a creative t3 MULTIMEDIA speakers (they are gift from long ago anywway), is it wise for me to get a KRK RP5 monitor speakers (i am tired of multimedia speaker and want to get something like the monitor speakers)? i could get that at a bundle with stand which i like how my full set up gonna be (Affordable also).
4.I am confuse about Multimedia speakers (the one with subwoofer) and monitor speakers (built in subwoofer?) which one is better?
5.I have read about passive speaker and active speakers and i don't really understand, how are they related to monitor and multimedia speakers?
appreciated and thanks!
geposted Thu 22 Mar 12 @ 8:34 am
mixer would have to be MIDI controlled
geposted Thu 22 Mar 12 @ 9:04 am
i have another question
Can the numark V7 monitorize MIDI turntable works with digital mixer?
geposted Thu 22 Mar 12 @ 9:05 am
so any digital mixer will do?
geposted Thu 22 Mar 12 @ 9:06 am
i use CDJ 400, DJM 400/350... my CDJ 400's are MIDI controlled.
has the V7 got USB conections... if it has, yes you can use it via usb and control it.
if you want to control VDJ program via mixer, it has to have MIDI controlled via usb.
chat tommorow... need sleep, im sure someone else will help you out.
thanks panos
thanks panos
geposted Thu 22 Mar 12 @ 9:17 am
ok thanks for the clarification! cheers
geposted Thu 22 Mar 12 @ 9:21 am
you mite need to download a mapper or 2 for the decks and mixer... check out
https://virtualdj.com/addons/controllers.html
geposted Thu 22 Mar 12 @ 9:24 am
uuuuhhhhhhh i'm confused about some of your questions, especially number 1
if you would like help with these questions i can help , you could PM ( use the private messaging ) for info
KRK make good speakers
passive speakers require an amplifier , active speakers are self powered and have there own amplifier
i use both types
you really can't talk about speakers in isolation , there's always factors like how loud do you need
the music in how big of a space with how many people in it? or what kind of music ?
i use both types
geposted Thu 22 Mar 12 @ 4:28 pm
i use both types
i use both types
hey thanks for the info dude! actually i am looking for speaker with deep base for electro house genre, instead of having subwoofers will built in amplifier be good enough?
geposted Thu 22 Mar 12 @ 11:43 pm
i use powered amp speakers and they are just fine, i play same music as you.
geposted Fri 23 Mar 12 @ 10:10 pm
go for something like the krk rocket 8's they are by no means earth shaking but have a decent punch to them and are great inbetween studio monitors for production and dj speakers.
geposted Sat 24 Mar 12 @ 7:36 am
when designated as "monitor" speakers that usually means speakers for critical listening like for
mixing and mastering, usually speakers like that are smaller in size and power handling and have
a tight focus and you need to orient them in a equilateral triangle....the two speakers and yourself
each at one of the 3 angles ...
you should expect such speakers to sound good , even lower end cheaper ones
the better they sound and the more power they have = more $$$$
headphones would be monitor speakers also
if you have to provide your own sound system for your gigs , those multimedia speakers aren't going to
be enough
i think that for the time being you should have 2 decent active (powered) speakers and if later the money is there
then think about adding subwoofers
if you find yourself in a store to buy speakers , do some homework first; homework for speakers is never boring
and could save you from an expensive mistake..... get an idea how much power you need and test the speakers
with the music you intend to use them for, crank the bass if you expect to do that , etc ....
if you test the speakers with pop music , especially Justin Bieber i personally will revoke both your man card and your dj card !
i will replace your ringtone with minnie riperton, i will call you at 3 am and play Yoko Ono, i will .....
oh sorry ......i was just sampling some of wildcountryclub's coffee ...... that stuff can raise the dead
uhhhh just test the speakers with some good stuff ......
be enough
geposted Sat 24 Mar 12 @ 8:28 am
agree on the krk's, the best for studio work. 11/10
geposted Sun 25 Mar 12 @ 12:24 am
thanks people for the review, i know the difference already (: . actually what i want is more for performance mixing, for small gigs. i have seen the gemini rs408, is that good?
geposted Sun 25 Mar 12 @ 8:13 am
