Hi- just wondering how i can adjust the accuracy of the BPM slider.... it goes in increments of .5bpm and i would like it to go in increments of.1bpm if i can....
ALSO
how do i turn off auto beat syncing? i have tried the key mapping to no success... it automatically adjusts all my song BPM's when i press play.... VERY ANNOYING
Thanks
Daimo
ALSO
Thanks
Daimo
geposted Fri 23 Mar 12 @ 2:20 am
you need a 14bit pitch fader which will send out double the midi signals as normal so you can have a finer pitch resolution, unfortunately 7bit just is not capable of fine resolution, but for better results you can change the pitch range to 3% in doing this you will not have the the ability to mix songs with as big a pitch difference.
To stop the decks from auto syncing when you hit play, you need to disable smart play... On the default skin there is a lock just above the play button, make sure that isn't lit.
geposted Fri 23 Mar 12 @ 2:35 am
awesome thanks... how can i go about getting a 14bit fader?
geposted Fri 23 Mar 12 @ 5:01 am
actually dont worry- fixed the problem. thanks heaps- can do my mixes for radio again :P
geposted Fri 23 Mar 12 @ 5:02 am
This is a hardware feature - You would need to purchase another controller that has this capability (Most mid/high end controllers normally have it) and even some budget controllers released in the last year or so also have it.
Please see: https://virtualdj.com/wiki/MIDI%20controller%20pitch%20precision.html
Otherwise, use a smaller pitch range such as 8% or even 6% and you will get more accurate adjustments.
geposted Fri 23 Mar 12 @ 7:29 am
