I'm setting up my new laptop and have found that several of my .VOB and MPEG2 video files kind of stutter along,the audio is fine.These are videos that have worked fine for years on my old dell and they play ok on my new laptop with windows media player.
new laptop is a i7 with a nvidia 3gig video card,16 gig ram.I'm playing them off of internal hard drive.
I converted 180 of the mpeg2 files to mp4 and they now work fine but the .vob files are worse if converted to mp4.
geposted Fri 23 Mar 12 @ 9:38 pm
I also tried changing codecs to the window media player video codec and it is the same,the audio is slow compaed to to video portion.
geposted Fri 23 Mar 12 @ 9:51 pm
Try going into config and and in the video options, check "Decode while Hidden"
I used to have a huge stutter/ out of sync problem with all my mp4's and then i did that and it seemed to do the trick.
geposted Sat 24 Mar 12 @ 11:39 pm
i've the same laptop as you with the same problem, i've hit a dead end with vdj tech support, i think i'll have to buy a new lappy or switch to serato video
geposted Wed 28 Mar 12 @ 8:09 pm
Exactly what card do you have?
What does VDJ call the card in the video dropdown box?
What tweaks have you tried already?
geposted Wed 28 Mar 12 @ 11:07 pm
I have the same laptop and it works perfectly. You don't need to buy a new laptop. Answer the questions above and people will help you configure the settings so it works fine.
geposted Sun 01 Apr 12 @ 11:35 am
Maybe the 48kHz conversion option.
geposted Sat 07 Apr 12 @ 2:40 am
Got same problem on my old laptop
Found out it was the graphic card, that was about to crash.. so need to buy a new laptop...
geposted Sat 07 Apr 12 @ 6:40 pm
If you switch to serato, then you will have to use mp4 files any way so what is the point , maybe its the conversion you are using....................................
good luck
jamm
good luck
jamm
geposted Sun 08 Apr 12 @ 2:38 am
You say your old machine is a Dell, but you never say what your new machine is.
geposted Sun 08 Apr 12 @ 9:12 am
http://www.msimobile.com/level3_productpage.aspx?cid=6&id=340
I have found that converting my problem .vob files to .avi seems to take care of problem.
The software that I'm converting videos with is made by Imtoo and it works well.
My old Dell is a 2004 core duo 1.6 with 256 meg video card and 1 gig of ram,and I use a external seagate 3 terrabyte hard drive.This system works perfectly.
geposted Mon 09 Apr 12 @ 1:43 pm
I did try this and it didn't seem to have any effect,thanks for your input.
geposted Mon 09 Apr 12 @ 1:46 pm
VDJ does recognize my video card,so far I have used the registry editor and it helped my earlier problems with program crashing.
geposted Mon 09 Apr 12 @ 1:49 pm
@pirate,
You may just love me for this :p. I have a similar laptop that I bought in January. It worked perfectly out of the box. same video card. About 6 weeks ago... video stuttering. I reinstalled windows. reinstalled VDJ, reinstalled video driver... fresh clean install. Stuttering. Do a quick test... turn off hardware acceleration. does that video stutter quit? roll back the video card driver to a previous version. Nvidia's latest mobile GeForce drivers have created issues with certain programs. Virtual DJ is one of them. Hope this is all your problem is. Good Luck!!
geposted Tue 19 Jun 12 @ 12:38 pm
Thanks for your input NoWrath,my system is working enough to use and I carry my old back up Dell.
I'm going to sit tight and hope that next version of VDJ will magically fix all my problems, reading through the posts on this forum I can see that I'm not the lone ranger with this issue.
geposted Mon 09 Jul 12 @ 1:53 pm
I have just bought a new computer with windows 8. My video playback stutters when playing all the videos. do i need to download something to stop the stuttering?
geposted Mon 30 Dec 13 @ 3:06 pm
A nice bit of old thread digging you've done there!
To answer your question you need to provide much more info.
What spec is the computer? Does it have a dedicated video card or is it integrated & using system RAM?
geposted Mon 30 Dec 13 @ 3:09 pm
What are the specs of your laptop? How much RAM, type of video card and how much memory does it have? You know the basic stuff.
Im also experiencing the same problem, Im running VDJ7 on a Windows 8 platform, laptop is HP Probook 4340s i5, direct x 11, intel HD graphics 4000 card. Apparently videos on serato run flawlessly but on VDJ7 they seem to stutter with lag on video. If I uncheck hardware acceleration, recording is disabled but videos run smoothly. what could be the issue? These used to work pretty well on my Core 2 Duo Hp laptop...
geposted Fri 10 Jan 14 @ 11:01 am
geposted Fri 10 Jan 14 @ 11:11 am
