this plugin has a LOT of potential, but i believe its very limited at the momen with just 12 clips at a time.
it would be very helpful if it were increased to 24 or even multiple pages of clips
also i think it would be better if there was a master " play all, repeat, shuffle, randomise " option in the clipbank menu
it would also eliminate the need for a seperate clipbank plugin "clipbank random"
EDIT: i apologise as i realise this thread is better off in the "wished & new features" section....
geposted Sat 24 Mar 12 @ 9:03 pm
you can create multiple copies of the clipbank plugin, which is like having multiple pages.
https://virtualdj.com/homepage/tayla/blogs/4515/Multiple_Clipbank_Tutorial.html
geposted Sun 25 Mar 12 @ 10:41 am
Essential Media supports up to 48 clips, save and load 48 clips at a time, has random, auto play, size control, transparency, high res camera support, Flash SWF, etc.
https://virtualdj.com/addons/12968/Essential_Media.html
geposted Sun 25 Mar 12 @ 12:12 pm
thankyou both
essential media is a good tool too im glad i discovered it thanks
from what i see though the plugin does not have "sync"
that is the only issue
and the duplicate clipbanks, though useful, still poses a small problem since only one of these can be assigned as the default plugin for audio only files
since im also layering a DJ logo JPG on top of the video, if i activate clipbank number 2, this turns off my Logos :( so i still think its better for the clipbank itself to have more banks
geposted Sun 25 Mar 12 @ 2:55 pm
To get your logo back on top simply deactivate the logo plugin you are using and then reactivate, simple work round solution for the present time.
geposted Sun 25 Mar 12 @ 7:50 pm
