I am trying to map my mixtrack pro to 3 deck use so i am facing these problems but i will also tell you how i mapped.
Master volume mapped as deck 3 volume slider
back button as deck 3 load
stutter as deck 3 play pause
keylock as deck 3 select
so i want to map either one of the effect control knob into jogwheel touch so that i am able to make a "jogwheel" for deck 3 so how am i able to do it? I tried using the jogwheel/touchwheel +1.0 and it doesn't act like the jogwheel as it can only forward the song when i turn the knob in back and front. (hope you understand me at this point)
or is it possible for me to map the pitch bend button as deck 3 and 4 select so that the whole mixtrack pro will be divided as deck 3 and 4, also 1 and 2 .
geposted Mon 26 Mar 12 @ 1:48 am
You need to know when your 20 day trial ends you will no longer be able to use these mappings unless you upgrade to Pro.
You should only need to map it as "param_multiply 5% & jogwheel" I am not sure what percentage it should be but smaller is less sensitive. You could also change the mixtrack to a four deck controller, there is a script in the wiki to do it
https://virtualdj.com/wiki/VDJScript%20Examples.html
https://virtualdj.com/wiki/Control%204%20decks%20with%20a%202%20deck%20controller.html
geposted Mon 26 Mar 12 @ 4:33 am
Hey guys Im having a problem mapping new effects to my mixtrack pro II does anyone know how to do that. I'm using virtual Dj, but mapping the actual effect it's self is whats proving to be the problem.
geposted Thu 06 Jun 13 @ 11:12 pm
Click on the first link Synth posted..........
geposted Sat 08 Jun 13 @ 9:59 am
