It's very, VERY disappointing how many skins support a 1600x900 skin resolution. Right now I have been looking around for about 15 minutes and found only 3 skins that support the said resolution. However, upon downloading and installing one of the three opens my browser and starts opening the Virtual DJ help.pdf for about as much as my computer can handle, and crashes (dark_default). The other two simply respond with an error, that says something about an XML error.
Is there anywhere I can just download and install a skin that supports 1600x900 without problems?
Thanks in advance.
Thanks in advance.
geposted Wed 28 Mar 12 @ 9:10 am
It's dissapointing that you have the dark minimal skin but are not a registered pro user as that is the only way to legally obtain it. If you were registered you would also have access to the skin re sizer...
geposted Wed 28 Mar 12 @ 9:23 am
What are you talking about? I bought a hercules mk4 along with Virtual DJ. I can assure you I'm having a lot of fun with it, but I can also tell you my wallet wasn't so very happy with it. Now I'd like to have a 1600x900 skin, and I downloaded ALL skins that I ever downloaded on this very site.
geposted Wed 28 Mar 12 @ 9:33 am
I find it really absurd how you even ignore my question and switch over to legal measurements.
geposted Wed 28 Mar 12 @ 9:34 am
Your Hercules MK4 came with VirtualDJ LE, which is limited software. As a LE user, you can download skins, but they are only usable during the 20 day trial of the full Pro. Please see: https://virtualdj.com/products/comparison.html
The version that comes with Hercules Mk4 is also an older version of the software (v6), so if you are trying to use a skin designed for VirtualDJ v7, then it will not work. Skins designed for newer versions of the software are not compatible with older versions. Dark default is designed for VirtualDJ v7.
You can search for skins by resolution by choosing the 'Show all skins' option and then selecting the appropriate resolution in the drop-down box, e.g: https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=1600&search= (Most of these require VirtualDJ v7.)
Please bear in mind that most skins are made by talented users of the VirtualDJ community.
You can try out v7 skins in Home FREE https://virtualdj.com/download/free.html , but this will only work for 10 minutes at a time with your Hercules MK4.
You can upgrade to the latest full VirtualDJ Professional at a discount by going to: https://virtualdj.com/buy/
geposted Wed 28 Mar 12 @ 9:45 am
maybe you are telling the truth because I count 17 for pro users... I have never had LE
if you can download the skin resizer tool you can resize any 1920X1080 skin as it is the same ratio
geposted Wed 28 Mar 12 @ 9:48 am
