Heya people,
I got a question for you guys.
Some MIDI controllers have a free virtualDJ LE edition with them.
So I've got 2 questions:
Question 1
Imagine I have 2 MIDI controllers.
I buy MIDI controller 1, which has a free LE edition code. I install VirtualDJ LE with MIDI controller 1.
I use virtualDJ with MIDI controller 2, which has no free LE edition code, but is supported by VirtualDJ (at the hardware list).
Will it work with VirtualDJ?
Question 2:
So I have virtualDJ and i still have the 2 MIDI controllers.
I used MIDI controller 1 to install VDJ LE, and want to upgrade to VDJ PRO.
If I upgrade, can I still use another MIDI controller, even if I have installed VDJ with Controller 1?
thanks
Question 1
Question 2:
thanks
geposted Wed 28 Mar 12 @ 10:12 am
1. VirtualDJ LE is limited software and will only work with the MIDI controller it was included with.
2. If you upgrade to the full VirtualDJ Professional, it will work with ANY supported controller: https://virtualdj.com/wiki/VirtualDJ%20Controllers.html - You can even use more than one controller at the same time.
Please see: https://virtualdj.com/products/comparison.html
geposted Wed 28 Mar 12 @ 10:34 am
So, if i use LE, i can only use it with the controller I bought?
And if I upgrade to full, I can use any controller?
geposted Wed 28 Mar 12 @ 10:40 am
Yep you got it right there mate.
geposted Wed 28 Mar 12 @ 10:44 am
