Hi,
I use virtual dj with CDJ 850s and Rane TTM57sl to control virtual Dj 7.0.4. It has been playing well for the past two months until recently. One deck is always playing faster than the other at the same BPM, tempo, & Pitch thus making it difficult to beat match. What could be the problem? I prefer using virtual dj because my laptop is slower for Serato Scratchlive thus is can't handle long hours.
Dj Que
Dj Que
geposted Fri 30 Mar 12 @ 3:44 am
Please enter your pro licence and download the latest 7.05b version as the one you are using is outdated.
Keith
Keith
geposted Fri 30 Mar 12 @ 4:10 am
It did, thanks.
geposted Tue 10 Apr 12 @ 5:21 am
I have Virtual DJ Version 7.0.5 Pro.
I have been using it now for a couple of years with no issues whatsoever. All of a sudden, about 2 weeks ago, when I am playing a song on 1 deck, I load a song onto the other deck, and when I hit play, the slider on the pitch changes and the song is either playing faster or slower.
It's not every song, it's random. I need the pitch slider to stay in the middle unless I change it myself. I'm not using the sync or anything of that sort. I thought the problem would correct itself when I shutdown and rebooted but it happened again last night. I have the auto pitch matching and the pitch reset on load both on disabled.
HELP!!!
Thanks
HELP!!!
Thanks
geposted Sat 05 May 12 @ 9:16 am
Please don't post the same message more than once.
You have already asked the same question in the following topic: https://virtualdj.com/forums/164038/PC_Version_Technical_Support/PITCH_SLIDERS_CHANGE_ON_THEIR_OWN__HELP__.html
geposted Sat 05 May 12 @ 4:20 pm
