Hello,
I just picked up the Voxoa C50 controller.
I had some trouble getting it to work on my 27\" IMac at first, but now it seem to recognize it okay.
However, I get a syntax error on the Jog wheel and they don\'t work at all. everything else is working fine.
Here is the Jog wheel mapping:
<map value=\"JOG_TOUCH\" action=\"touchwheel_touch\" />
<map value=\"JOG\" action=\"var '$shift' ? wheel_mode "jog" ? wheel_mode "search" on & touchwheel : touchwheel : wheel_mode "search" ? wheel_mode s"jog" on & touchwheel : touchwheel\" />
Any ideas as what the problem may be?
geposted Fri 30 Mar 12 @ 6:56 pm
Please revert the mapper to default (factory) settings, by choosing the button on the bottom left of the Mappers tab, and try again.
geposted Fri 30 Mar 12 @ 9:59 pm
I still get the same results. :(
geposted Sat 31 Mar 12 @ 12:19 am
Do you still get syntax error after reverting the mapper to default settings ?
Here is the default action..
var '$shift' ? wheel_mode "jog" ? wheel_mode "search" on & touchwheel : touchwheel : wheel_mode "search" ? wheel_mode "jog" on & touchwheel : touchwheel
which doesnt give any syntax error here..
Also check the manufacture website to see if there is a firmware update available, and make sure you have the latest Le version from your DOwnload Center .. https://virtualdj.com/download/updates.html
geposted Sat 31 Mar 12 @ 9:31 am
