I'm having problems setting up the audio part via the gemini ASIO driver. When I go into the sound configuration part, I set it up under external mixer, Asio, then I select the Gemini Asio, but when I load up the tracks, I'm only getting audio form one channel. I've tried just about everything possible to see if I can get the sound correctly, but no luck. I'm using the Gemini CDJ700 and the Behringer DJX900 USB, would you guys be able to assist me with this minor dilemma?
geposted Sat 31 Mar 12 @ 10:31 pm
Solved the problem. It was just the way it needs to be configured, and I have it up and running now. I guess this post can be deleted or closed.
Thank you.
Thank you.
geposted Sun 01 Apr 12 @ 1:52 pm
