I did this some years ago when I had the Numark Mixtrack and forgot the steps, bought the Numark DJ TO GO controller but forgot the steps to get it to work, help please?
geposted Sun 01 Apr 12 @ 9:13 am
As far as i know it should be Integrated with vdj so you just have to plugin and you are ready to go but for manual maping check out https://virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html :)
geposted Sun 01 Apr 12 @ 9:36 am
Oh, thanks.
geposted Sun 01 Apr 12 @ 10:53 am
Oh, another question, this DJ 2 GO controller came with a lite version of VDJ on cd but when I instaled it I think it said I have 20 days or so left, does this mean it's only a trial version? If yes, how much is the cheapest version one can purchase to work with this controller please?
geposted Sun 01 Apr 12 @ 12:10 pm
The 20 days is for the trial-version and will have all the functions of the Full Pro-version. After that it will become the LE (or Lite)-version. This will work fine with the controller.
Since you're already a Pro-user, the DJ2GO would work with your Pro-version. If not, just download the latest version of VDJ from your Download Center. VDJ is regulary updated with the new controllers coming out but the version-number remains the same.
:D
:D
geposted Sun 01 Apr 12 @ 12:16 pm
you already have vdj pro registered in your name, just go to your download centre and get the latest version then it's plug and play.
edit --> i've got to press send quicker LOL :-)
geposted Sun 01 Apr 12 @ 12:22 pm
Removed the post, was explained above
geposted Sun 01 Apr 12 @ 12:23 pm
Thank you very much guys!
geposted Sun 01 Apr 12 @ 12:42 pm
dont forget to register your LE code from your dj 2 go on your profile too, then you get your pics over there <<<<<<<<<<
geposted Tue 03 Apr 12 @ 7:31 am
if you have problems with setting up the controller go to configure and make sure if your using a mixer with a built in soundcard that its set on that soundcard under the last scrolldown menue and for me with the numark mixtrack pro i have to set the audio output to headphones i dont know why but it works great
geposted Tue 03 Apr 12 @ 8:11 am
