I'm using VDJ Pro with the MC3000 soundcard, and the mix doesent feel smooth.
I've had this problem before with other controllers, and I've fixed it adjusting the latency. It helps when mixing house that the kicks match up better, and it feels more "in the pocket".
With this soundcard it's a bit harder to adjust due to such a wide range of buffer the audio card control panel has. It's not just a 128, 512, or 1024.
I was wondering what the ideal latency is for this card is to use with VDJ.
See my specs below
AMD turion 2 ultra core mobile 2.4ghz
4gb
64 bit
See my specs below
4gb
64 bit
geposted Sun 01 Apr 12 @ 4:58 pm
[Unnecessary self quote removed]
I tried to edit the subject but couldn't :\
geposted Sun 01 Apr 12 @ 5:01 pm
