Hi Guys
I am looking for some help with using Virtual DJ with my Serato SL3 Box
for some reason I can’t seem to get sound out of VDJ so i was looking over the audio settings of VDJ but it seems very complicated to me
I have a Macbook pro and all I really want to be able to do is keep it as real as possible
Here is my set up
Macbook
Current version of Serato
SL3 box using USB
Serato Vinyl
Virtual DJ free
Pioneer DJM 600 Mixer
2 x Technics SL 1210s
I do plan to buy the full pro version of VDJ so I contacted support explaining what I was looking to do and they sent me a PDF off the Manuel (that I already had)
I Would be grateful if anyone can give me some help on what the audio settings should be on the VDJ on the mac and what position the dip switches should be in on the Serato box
Thanks in advance
Cheers
Scott
Here is my set up
Macbook
SL3 box using USB
Serato Vinyl
Virtual DJ free
Thanks in advance
Cheers
Scott
geposted Mon 02 Apr 12 @ 7:47 am
I think you need to have VDJ PRO FULL to use an external soundcard, you can use Home FREE to test for 10 or 20 mins at a time though.
geposted Mon 02 Apr 12 @ 2:58 pm
