The radio station where I usually broadcast my show is shutting down in a few weeks. Anybody know where I can go to continue broadcasting my radio show? or simply, hot to go about setting up an internet radio station of my own?
geposted Tue 03 Apr 12 @ 10:28 am
There are a couple of places that you can go.
Virtual DJ Radio
Listen2myradio
Ustream------can use video camera to show your audience what you are doing
Stickam-------Same as Ustream just stickam will allow your audience to use there cam as well.
There a more out there that you can search on google or even try out for Virtual DJ Radio.
Hope this helps
Charlie
Virtual DJ Radio
Listen2myradio
Hope this helps
Charlie
geposted Tue 03 Apr 12 @ 12:36 pm
Thanks Charlie, I will look into some of the ones you mention.
geposted Tue 03 Apr 12 @ 12:43 pm
