when i'm using vdj & i open a dialogue box like "file info" or if i'm loading a slide show the window stays on screen, causing me to have too disable the video output to get rid of it !
i'm using the correct skin size for my laptop, any idea's guys ?
geposted Tue 03 Apr 12 @ 5:44 pm
Yes, disable Aero in windows :)
geposted Tue 03 Apr 12 @ 6:22 pm
Make sure you dont have any other programs interfering with vdj update windows and close unnecessary programs set your monitor resolution to a lower one.
Hope helps
Hope helps
geposted Tue 03 Apr 12 @ 11:39 pm
SBDJ is right it is a problem with AERO on windows 7, turning it off sorts it out. I have a few guides on my home page to optimise your PC for DJing and turning off AERO.
Hope this helps
Hope this helps
geposted Wed 04 Apr 12 @ 5:04 am
