How can I set the default video transition to 'fade'
It's on another one which I don't really like and it's annoying having to manually change this every time
Thanks
Thanks
geposted Thu 05 Apr 12 @ 7:34 am
you could map "ONINIT" for your controller or "init" for your skin... Athough I can't find one called "fade" so you will need to change it to the correct name
video_transition_select "fade"
geposted Thu 05 Apr 12 @ 7:53 am
