ΓΕΙΑ ΣΑΣ ΠΑΙΔΙΑ. ΞΕΡΕΙ ΚΑΝΕΙΣ ΤΙ ΡΥΘΜΙΣΕΙΣ ΠΡΕΠΕΙ ΝΑ ΓΙΝΟΥΝ ΣΤΟ JOG ΤΗΣ DDJ/ERGO ΩΣΤΕ ΝΑ ΔΟΥΛΕΥΟΥΝ ΣΩΣΤΑ (ΜΑΛΛΟΝ ΣΤΑ MAPPERS ΠΡΕΠΕΙ ΝΑ ΓΙΝΟΥΝ ΚΑΠΟΙΕΣ ΑΛΛΑΓΕΣ ΑΛΛΑ ΔΕΝ ΞΕΡΩ ΑΚΡΙΒΩΣ ΠΟΙΕΣ..). ΕΥΧΑΡΙΣΤΩ!
geposted Fri 06 Apr 12 @ 2:35 pm
Σωστά;;; Δηλαδή
Υ.Γ. Κλείσε το CAPS LOCK. Είναι σαν να φωνάζεις...
geposted Fri 06 Apr 12 @ 5:21 pm
Τι δηλαδή Phantom?
geposted Fri 06 Apr 12 @ 5:36 pm
Τι θεωρεις οτι δεν κανουν σωστα τα jogwheels και θελεις να διορθωθει η να αλλαξει¨...??
geposted Fri 06 Apr 12 @ 6:36 pm
i proepilogi sto jog den exei kamia sxesi me ti hercules p.x. kat'arxin doulevei antistrofa kai defteron trexei para poly. tin exw stisei se 2 pc kai kanei akrivws to idio kai sta dyo. opoios tin exei doulepsei kserei. peiraksa kai ta mappers opws kai tis evais8isies stis epiloges tou config alla mia apo ta idia. prospa8w na petyxw tin evais8isia tis hercules alla vlepw diaforetiki fasi edw. 8a dokimasw oti mou eipes apopsis.
geposted Sat 07 Apr 12 @ 1:46 am
de diefkrinisa oti pio poly me endiaferei to pws doulevei sa pitch to jog kai ligotero sa scratch.
geposted Sat 07 Apr 12 @ 1:49 am
dokimase na mapareis to JOG me thn entolh scratch_wheel kai to JOG_TOUCH san scratch_wheel_touch kai pes mas kai mhn ksexaseis na ksanarythmiseis tis euaisthsies
geposted Sat 07 Apr 12 @ 3:59 am
paidia ekana oti mou grafete alla tzifos. einai kati diaforetiko. de mou exei ksanatyxei. ektos ki an exei provlima i konsola. alla kai sta dyo jogs mou fantazei api8ano..den kserw ti na ypo8esw..
geposted Sat 07 Apr 12 @ 5:48 am
paidia molis diapistwsa pws otan anoigw tin LE version (afti pou mou pareixan sti syskevasia diladi) ola doulevoun kanonika. otan omws anoigw tin 7.05b pou tin exw agorasmeni ekei yparxei to provlima
geposted Sat 07 Apr 12 @ 6:26 am
ypoptebome pos den exeis thn teleytea ekdosh 7.05b(380) alla kapia progenesterh gia ayto tsekare an einai h 380 kai an den einai katebase thn teleytea kai 8a eisai ok!!!
geposted Sat 07 Apr 12 @ 6:51 am
ontws sadim, tin b370 exw. apo pou omws 8a katevasw tin 380?
geposted Sat 07 Apr 12 @ 6:54 am
apo to download center ths atomix apo poy aloy? lol
ksana katebase to exe einai neotero apo ayto poy exeis kai periexei kai thn ergo alla kai alles konsoles neoteres
geposted Sat 07 Apr 12 @ 6:59 am
ola ok sadim. se efxaristw poly opws kai ola ta paidia pou kanete foveri douleia!!
geposted Sat 07 Apr 12 @ 7:31 am
geposted Sat 07 Apr 12 @ 8:46 am
ola entaksei paidia alla apopse tin egkatestisa se ena trito pc pou exw sto magazi mou me xp kai vgazei ena sfalma kati san provlima me ena xml. den to sygkratisa giati tin evgala gia na paiksw mousiki me ta cdj 400 pou eixa prin.
geposted Sat 07 Apr 12 @ 4:51 pm
yp'opsin oti sa xiristirio doulevei mia xara (xrisimopoihsa tin traktor audio 2 pou exw)
geposted Sun 08 Apr 12 @ 5:17 pm
An to error pou sou vgazei einai Error in skin file xml i kati paromoio, tote katevase to Registry Tool https://virtualdj.com/addons/2170/Registry_Tool kane CLean All, kai meta egkatestise ksana to VirtualDJ.
geposted Mon 09 Apr 12 @ 9:30 am
molis to dokimasa dad. doulevei alla otan to kleinw mou vgazei pali to sfalma ''Error opening Xml plugin file''. Pou simainei pws an doulepsei ligh wra 8a ksanakolisei (opws mou ekane proxtes dilidi).
geposted Mon 09 Apr 12 @ 12:05 pm
Αυτό το μήνυμα αν θυμάμαι καλά το βγάζει όταν κάτι πάει στραβά την ώρα που κάνεις scroll τα effects. Με λίγα λόγια κάποιο απο τα effects που έχεις εγκατεστημένα έχει κάποιο θέμα...
Θα σου πρότεινα να μετακινήσεις ΟΛΑ τα αρχεία από τον φάκελο C:\Users\YourUsername\Documents\VirtualDJ\Plugins\SoundEffect σε ένα πρόχειρο φάκελο και να αντιγράφεις μετά ένα-ένα τα αρχεία dll ΜΟΝΟ πίσω στην αρχική τους θέση δοκιμάζοντας κάθε φορά να κάνεις scroll την λίστα των effects από τον controller. Άφησε τελευταίο το TK Filter V2.dll
Αφού βρεις ποιο effect σου κάνει τη ζημιά γράψε μας εδώ για να βρούμε την λύση.
geposted Mon 09 Apr 12 @ 12:33 pm
to minima lei gia xml plugin file
kai ayto moy kanei kati apo effect
kitakse mpas kai to sfalma proerxete apo kapio effect
geposted Mon 09 Apr 12 @ 12:36 pm
