I bought a denon mc 3000, all is good, except still figuring out a issue, may be I am doing something wrong. The loopout v2.01 effect that i downloaded here usually starts at the max volume and goes down, typically i keep my master volume and 8 or 9 clock, so how does this work? i really need to have my channel faders all the way down otherwise i get loud volumes when i press the loopout effect.
or do i keep master at very low and keep using channel faders? this will not give good sound quality though.
How do you guys do it?
geposted Fri 06 Apr 12 @ 5:37 pm
