How easy is it to change the text colour on decks? I'm using the VDJ home (free) version with a 4-deck skin.
I assume it's a case of altering the skin file somewhere?
geposted Fri 06 Apr 12 @ 6:04 pm
Anyone? :-(
geposted Sat 07 Apr 12 @ 4:32 am
Guess not then... :-(
geposted Sat 07 Apr 12 @ 12:28 pm
you cant modify the skin in vdj home, or for that matter you can't modify anything apart from mapping the keyboard.
In VDJ Pro you are able to modify the skin xml in notepad... if you search for "color" you will jump to the different textzones there you can change the color eg if you want blue change it to color="#0000FF". you can even change the font, text size and whether it will scroll.
blue "#0000FF"
cyan "#00FFFF"
red "#FF0000"
green "#008000"
blue "#0000FF"
cyan "#00FFFF"
red "#FF0000"
green "#008000"
geposted Sat 07 Apr 12 @ 2:45 pm
Cool - what is the code for Yellow?
geposted Sun 08 Apr 12 @ 10:15 am
http://html-color-codes.info/
that's all of them ;-)
geposted Sun 08 Apr 12 @ 1:16 pm
