Hello,
I'm a beginner, and I want to mix a song. But I have to start manually many effects during the song, for recording. I really can't repeat them every single time i want to record the song, so i'm asking if there's a way to do something like that:
- At 0:05 seconds, start the phaser effect. End phaser effect at 0:07
- At 0:09 seconds, start "that effect". End "that effect" at 0:13
So to time all the effects, so everytime i play the song it just follow the instructions and mix it in the right way. To start and end effects in a not manually mode.
geposted Sat 07 Apr 12 @ 5:17 am
If you really want to do the same things at the same time whenever you play the song, the easiest way would be to add the FX permanently to the song.
Load your song into an audio editing program, then apply the effects you want and save it as a new file.
Call it 'artist - title (FX version)' etc. so you can find it easily.
geposted Sat 07 Apr 12 @ 6:23 am
