Topic: Virtual DJ Library Question
I have created a large library in Virtual DJ Pro with over 40,900 tracks in? It has taken me ages to scan all the BPM's and create user virtual folders for gigs etc, so I don't want to have to start from scratch creating a new library.
In the settings menu under Data Base for my Drive I am seeing 2 present but hidden from search????
Is there any way to find out which two this is? or to simply delete them?
I have tried using the "Check" and "Clean" to no avail.
I know its not a big issue, but it bugs me when I can't find out how to correct this small problem?
Is there a way to remove or show where these two hidden entrees are coming from? Like an library/database reader/editer?
Thanks in advance
Paul
geposted Sat 07 Apr 12 @ 9:38 am
Paul, it's a XML-file and readable in a text-editor or browser.
You can add a song and see which one is updated (It should display the current date under "Last change")
Martin.
You should backup your database on a regular basis if this information is important to you: https://virtualdj.com/wiki/How%20do%20I%20backup%20my%20VirtualDJ%20database%20and%20settings.html
Also, make sure that you backup your entire music collection.
NOTE: VirtualDJ Home FREE cannot be used at gigs where you are being paid. It is for non-commercial use only. For paid gigs, you will need to purchase VirtualDJ: https://virtualdj.com/products/comparison.html - Please support the software and its future development by purchasing it, especially if you make money from gigs where you are using it.
