Greetings
I have just started using Virtual DJ LE that came with a Numark Mixtrack controller, and am really liking it. It is a very intuitive design.
My music library is organized in windows by artist folders.
I'd like to have Virtual DJ show me tracks in my whole music folder by genre or bpm or comment, rather than scroll through the folder structure as it exists on my hard drive.
Is there a way to do this? Or, is it a feature of Virtual DJ Pro?
Regards
Rolf
Regards
Rolf
geposted Mon 09 Apr 12 @ 12:15 am
Be shure that all your music is in the vdj\'s database.
If so, do what you see in the picture (don't know if you can with the LE version).
You can work with virtual folders or filter folders to..
Best regards,
John
Best regards,
John
geposted Mon 09 Apr 12 @ 1:02 am
Also you can try to right click on the root folder (the folder that has all the artist subfolders) and select "Recurse"
This operation can take some time (up to a few seconds for very large collections) and needs to be redone every time you leave the recursed folder. However if all your music is inside a single root, recursing this root will show you all your files and you won't have to recurse everytime since you are going to work inside the recursed folder all the time.
geposted Mon 09 Apr 12 @ 2:10 am
Thanks! These were the answers I needed.
geposted Tue 10 Apr 12 @ 4:19 am
