Hey everyone I just purchased Virtual dj 7 pro and my video is freezing last time a friend had this issue he changed the settings on NVIDIA. Its not working for me any suggestions, are greatly appreciated.
geposted Mon 09 Apr 12 @ 8:39 pm
Hi,
I've just resolved a similar issue. The response I got from my ticket is as follows:
Although your computer has an Nvidia card it probably uses the onboard Intel graphics as default for programs.
First open the device manager and confirm my though that there are 2 video cards.
If yes, right click on the virtualdj icon in the desktop and you will probably see an Nvidia option to run with high performance graphics, also a way to open this selection permanent.
This will force virtualdj to use the nvidia card instead.
In the registry tool the only option you need to try is "VideoYV12Bug"
(Apply and close).
This will fix your problem if when the intel graphics are used.
Please leave the other values to default (VideoMemMax Use=0)
(Apply and close).
geposted Thu 07 Jun 12 @ 1:19 am
Thanks, i solved my problem with this topic ... thanks a lot
Massimo
Massimo
geposted Wed 08 Aug 12 @ 12:03 pm
