Forum: Old versions
Topic: Recording a Mix Please help ASAP
Hello.. I am runnin the latest version of Virtual DJ on my HP Pavilion Laptop on Windows 7. I have the Stanton T.92 USB direct drive turntable and a stanton M.203 Mixer. I'm having trouble recording a set. I know how to record, but when im playing a track, and then I hit clone deck, it works perfectly, but I can't controller the volume levels from my mixer. When I listen to the mix after ive recorded for a minute or two, you can still hear the opposite deck's song playing even after I have moved the cross fader all the way to one side. I did troubleshooting and found out that I guess everything was still being controlled by the on screen mixer on the program. Is there anyway to disable the on screen mixer when I can just control everything from my stanton mixer to record a proper set?
geposted Mon 09 Apr 12 @ 9:12 pm
This is because you are using an external hardware mixer.
Please see our FAQ pages:
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
NOTE: To use timecode and an external mixer you will need to purchase the full VirtualDJ Professional: https://virtualdj.com/buy/
If you have already purchased, please register your Pro serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it.
